Whining 40
Dallas, TX
My 40 whines loudly while in driving in gear (it doesn't when clutch is depressed). It sounds like it is from them front end. I have heard various theories...check the tranny, hubs (it is a 3/79 and doesn't have manual locking hubs). As a new owner, is it normal to have a whining 40 or is it something I need to get checked out?
That sounds like a throwout bearing problem
Some whining in these old trucks is somewhat normal. The 79 should not be as bad as the pre75 trucks with the 3 spd.
Of course, you have checked all the fluid levels in the diff, tranny, and TC?
sounds like my idler shaft bearing issues in the T case... it wasa bitch to diagnose till it siezed
There are a lot of possibilities, so bite the bullet and localize it more accurately, so you don't have to guess. If you can hear the noise when it is running with the wheels off the ground on jack stands, that might help, but you want to stay clear of the vehicle when it is running.
pre 74 trucks :D They can be a little whiney even with the h42(i think that's what it is...stock 74 fj40)
