While I'm doing PHH, I should also do...
DocuDude
Took me 10 years to find this space
Los Angeles
So finally doing the PHH.
While I got the DS tire off and the Cruiser up, what else should be replaced near there?
:moon:
:rolleyes:
un i would submit that the mere fact your DS tire being on / off is not necessarily an arbiter as to what needs to be repaired-
now as the the PHH - since you are "breaking" the H20 system - can "flush" the system (many debate this effectiveness) - then do the FHH, HCV, thermostat, water pump, and rad hoses.
Bf
Thanks.
I should clarify, I did the HCV and rear heater hoses that connect to firewall.
You are right @Pin_Head, the HCV was brittle and failing.
Working my way through all coolant/heather hoses.
I don't like being under the jack stands, so what is done in this area of the car when in the air?
PHH
Thermostat
What else?
Perhaps a fuel filter.
The other heater hose that lives in the area, forget what it's called right now.
...surgery for the carpal tunnel syndrome you're going to develop by twisting your hand/arm a thousand different ways to get to the PHH.
starter contacts. If you already did the PHH then don't bother, but removing the starter makes the PHH a breeze and you can do the contacts in a couple minutes.
when I do them I also do the fuel filter and starter contacts if the vehicle owner is crazy about preventive maintenance. Also consider the thermostat if it's more than 5 years old.
