I have 3 D31A Yellow Top Optimas. Two in my truck, One in my wife's.
I got the one in her truck by ordering it through an auto parts store (O'reilly's) for about $180 + shipping = $200. When I got the first one it was a gamble because I wasn't quite sure that it would fit.
They fit like a glove. IMHO they fit as well if not better than a 27F. Here's some pics. You'll only have one of the two battery trays if you haven't done some minor work already.
https://forum.ih8mud.com/showpost.php?p=1313490&postcount=26
When I was doing mine I planned better and ordered a pair of them for $300 shipped through the web. The key was to order them as a two battery pack.
They're still not cheap by any measure.
It's a smidge misleading to state that the D31a "fitas well if not better than [the OEM] 27F." Although the battery fits well in the tray and the OEM hold-down works fine, the OEM battery cables will not reach the posts of the D31a without removing some of the OEM cable ties and rerouting the cables a bit. Even then, it is still a stretch as far as the cables are concerned, and cable strain is an issue, IMHO.
Um, no... At least not in the case of my wife's bone stock '96 and my '96 before I modified things.
The Optima D31A has the posts in the dead center of the battery. It is a touch shorter in the front to back axis as well than a 27F. The result is that you only have to pull the cables through by about 1.5".
My wife's cables fit by just pulling gently and plugging them in. My '96 was the same story prior to my dual batteries. No modifications were needed and I don't feel that it strained the cables. I just went outside and felt the cables. They have enough slack to be gently pushed in any direction by about 2". I.e. no 'strain' on them at all.
My dual battery installation is a different story with a different purpose so the cables are completely re-routed through the switches. I included a link to that one above just for the LxWxD example.
In the case of my wife's '96 an Optima D31A fit perfectly including the cables with no modification. I had the same battery in my '96 before I transfered it into hers so that I could have two age matched in mine.
So did you try installing one yourself and have a different experience? If so, this may be a truck dependent question. Maybe my two '96s are different from your truck?
Perhaps Mr. T was a bit more generous with the cable on your trucks than on mine (also a 96). All I know is that mine took a fair amount of fiddling to get the cables to reach using a D31a. I'll eventually replace the cables when I go to dual batteries.
It would have made a terrible spare in a pinch.
