Where to Put a Bussmann RTMR Fuse/Relay Block
Arizona
Hey everyone! I have an '06 LX470 and am struggling to find a place near the battery to put a bussman rtmr fuse/relay block. I've seen the one here (What have you done to your 100 Series this week? - https://forum.ih8mud.com/threads/what-have-you-done-to-your-100-series-this-week.609679/post-13402006) but the LX has a second fuse block that prevents me from putting it there (see picture below). SO! I'm looking for some inspiration... show me how you've set up yours or any pictures you've seen of that setup. Thank you!
Edit: I have the Bussmann RTMR Same as in the link above and in this link DIY - Build and install a Bussmann RTMR Fuse/Relay Block - https://www.tacomaworld.com/threads/diy-build-and-install-a-bussmann-rtmr-fuse-relay-block.399454/)
What "fuse/switch block" are you using?
the Bussmann RTMR, same one as in the linked "what have you done" post and in this post: DIY - Build and install a Bussmann RTMR Fuse/Relay Block - https://www.tacomaworld.com/threads/diy-build-and-install-a-bussmann-rtmr-fuse-relay-block.399454/
I think I may have found space but will have to relocate the drivers air injection control module.
Oh ok gotcha
I've got something similar on the passenger side but you have AHC equipment in the way I think.
YotaMD has sorta something in the ballpark of where to put a mount, but this is made for a power shut off switch so I guess doesn't solve problem
>2006-2007 Land Cruiser/LX470 Battery Switch Bracket - https://www.yotamd.com/collections/misc-100-series-parts/products/battery-switch-bracket-for-06-07-100-series-land-cruisers-and-lx470
Could you run power over to passenger side? Looks like even with your AHC equipment you may have more space.
Oh ok gotcha
Thank you! That is actually exactly where I'm putting mine... though it will go low and in between fuse box 1 & 2. There are four threaded holes on that wall (all threaded the same). The holes aren't perfectly horizontal though so some mockups will need to be made before bending 0.1 inch aluminum plate. Two fixtures will be needed, one to relocate the air control module horizontal and one to put the bussman in. (the mounting holes for the module are exactly 85mm).
