A mechanic stopped by...no power to the distributor. He suspects the ignition ignitor. Where can I have it tested? 818 area code.
There is no test for the ignitor. Your best bet is to find someone that is local that will let you swap one in a good one to test.
89621-26010
Toyota ignitor
$15
ebay
...no power to the distributor. ...
I bought one off Ebay ($25 delivered) and it works fine (tested on my 80). Do note that if you plan to test another ignitor in your 80 you MUST screw it down to the bracket. The ignitor gets its ground connection through the bracket and will NOT work if you just plug it into the harness and let it 'dangle'.
The one I bought was listed as for "Toyota Tercel 3E-E 3EE COIL IGNITER 91-94 92 93 94 1994" which has the exact same part number as the one on my '97 80 series.
A friend had his 80 die on the road, it had no spark. Turned out that one (or maybe both) of the pickup coils in the distributor had failed (corrosion etc) and so the ECU would not fire power to the coil. So, plugs or output of coil not having spark can be more than just the ignitor failing.
cheers,
george.
I have tested on the car this way:
Unhook coil wires from igniter, connect a voltmeter (or 12V test light) to igniter in place of coil and crank. voltmeter should swing from 0V to 12V or test light should blink on and off.
Tests everything in the circuit from the ignition switch to the igniter output.
A mechanic stopped by...no power to the distributor. ...
I would check power circuits that feed it. My first check would be the fusible links at the battery, common problem that would cause your problem. The ignition igniter has proven to be very reliable.
... He did not see any power from the ignitor to distributor. No spark or power in the distributor, his words. ....
