Wheels - I keep looking but can't find them!
NJ coast
Ok, so i am looking to get some black wheels in 16x10 ( like the rock crawler 152 series) or similar. i have a 1997 lx450. i have seen a ton of people on this site with 16x10 wheels with 4.5" backspacing, but everywhere i look, these style rims and other only have 16x10 with 4" backspacing. where is everyone getting the 4.5's? does it really make a difference, will the 4" be ok on my truck? i am going to be running a 33x12.50. stock height
4" isn't going to make or break you...with that wide a wheel you're going to rub just as much at 4" as you would 4.5". You'll be more stable, but your wheel bearings might not be happy...don't worry, they'll let you know several thousand miles before they go.
unless you do excessive amounts of highway at high speeds, you probally will never notice the difference.
as well, the taller the tire the wider you should be going.
Also .5" per side isnt going to be significant. You will notice the tires getting the body a little dirtier than before. I have probally almost an inch more back spacing on the 80, and on the 60 there is 2" more on the rear and 1.5" less BS on the front, and i no problems with them yet.
I agree with Bomar, but some people like the looks of a 10" and aren't to be changed. I had 35x12.50 TrXus STS on 15x10 w/ 2.5" backspacing....very smooth and stable, wheel bearings didn't like it...but they didn't like the water much either.
my only problem with 16x8's is that they all have the 4 to 4.5 bs as well. this leaves me at the same stance as the stock wheels. i want a little more width, to bring the tires further out in the wheel wells. if i could find a 16x8 with 3 or 3.5 bs, i would consider it
i have a similar thread going for rock crawler type 51.. i'm trying to find 16 X 8 with 3.5" bs.. seems like a lot of mudders are not fond of wheel spacers here.. so gotta find the right wheel
yeah, im having the same trouble, but i cant find any company (cragar, unique, black rock, or pro comp) that actually makes those wheels in different backspacing. its weird, every wheel whether it be a 16x8 or 16x10 has 4" to 4.5" bs. im considering just getting the 16x10's. how bad are they on the wheel bearings? the truck is mainly going to be a street driver.
