Wheels for a 92?
Arizona
Im looking for new wheels to replace the chrome ones that are on the rig now. I have bben looking at some simple grey steel wheels off older Toyota trucks? What do I need to look for? Backspacing? How wide to run my 33x12.5 mt? Can any 15" Toyota truck wheel work?
Stock Toyo 15" rims were only 7" wide. That's too narrow IMO for a 12.50 wide tire. I would look for a 15x8 rim with a 4" or so BS. I run the AR 767 black spoke steelies for my woods tires.
Now keep in mind, the shape of the individual wheel will determine if it will clear the calipers for that amount of BS. I can just about get a credit card between the wheel spokes and the caliper on mine.
Jonheld So I need to check fit anything first? I need to look for a 15x8 with a at least 4" of back spacing
I think you need to go with a MAX of 4". Anything greater than that may have clearance issues. I went through a test fitting to find the ones I use now. It all depends on the shape of the wheel.
The greater the BS the closer the tires will be to the frame.
Stock FJ80 wheels (and mid-90s 4runners) are 15x7 w/ 4.5" of backspacing. 33x12.50 BFG ATs fit just fine, had to run @ <32psi to keep them wearing evenly but the ride was great. 15x8 would be better suited to a 12.50, and 3.5" BS would net more stability....but that's all preference.
Tire pressure is determined from a million things. Running a wide tire on a narrow rim makes the tire bulge in the center of the tread. To keep from wearing out the center faster than the sides you must lower air pressure accordingly. I guess technically you have a lesser load bearing ability with a fat tire on a wide rim...but you'll shock a lot of people if you ever lose a bead.
Well if you take off the flares, you get it looking just right. And too wide reminds me of those ugly american trucks lifted to the sky with douche bags rolling around inside them. :)
I don't have flares and my 33x12.50s on OE wheels stuck out less than 1/4".....they have a full 5" of backspacing. Understandable.....but I never look at my cruiser w/ 16x10s and 37x14 IROKs and think it's too wide. All in opinion...and if you're not lifted then your stability should still be great.
You could buy the ones I'm trying to sell.:cool:
Hmmm. I must have had my figures messed up. Sorry old fellow. I have 33X12.5's too, and personally don't like them because they stick out quite a bit. More than a 1/4 inch I'd say. They are constantly whipping rocks up and stuff. And I have flares. Hmmm... Maybe my trucks all whacky. :)
I saw yours, but Im trying to get away from chrome.
BTW can is there any rattle can paint you can use on chrome?
Looks about like 1/4" to me....
1/4" what? nevermind sticks out a 1/4"
