Wheels and tires question
West Jordan
I have the 17" 2010 tacoma rims. I have attached a pic of the rims and the specs. I am planning on getting a 2" OME medium lift and I want to know what spacers or hub adapters I need to make these wheels work with a 33 or 34" AT tire that will work well for street and AT applications.
Thanks guys!
I am running that very same set of wheels, with 255/80/17 Copper ST Maxx (true 33in tire) with a 1 inch spacer, and OME stock height heavy spring with 30mm spacers up front Puts the tire right back where they would be stock on a FZJ, and look great. If you want to run center caps you will need to do a little clearancing on the fronts and heavy mods on the rears and use magnets to hold them on the hub. But if you use a bit wider spacer you can use the caps with out issue
Nice to know. No i am not planning on having center caps. Do you have a lift as well?
