Hi, i would like to put wheel spacers in front and back of my 75 series anyone any experience with those(strenght wise) and what a good width is , thanks , these are the ones from landcruiser parts
Toyota Aluminum Wheel Spacers
Starting at: $89.00
Sale: $80.10
Save: 10% off
These bolt on wheel spacers are designed to give you a little more width without changing out your axle for a wider one. Great for use on solid axles conversions to make the front axle similar in width the wider rear axle found on 86 and up Toyota trucks. Bolt pattern is 6 stud on a 5.5" round circle. Features safety graded studs and matching nuts for proper fit. Made from Billet 6061-T6 aluminum. Grade 8 Studs, Grade 10.9 nuts. Five sizes available. Shipped as a set of 2 spacers w/nuts. Every spacer features a precision machined surface. Only high quality nuts and studs that are hardness graded and stamped are used. Six lug wheel spacers fit Toyota FJ Cruiser, Pickups, 4Runners, FJ-40, FJ-60 & FJ80.
Note: Wheel spacers are sold in pairs.
Available options:
Wheel Spacers, 1.00" Wide, $89 pair, 140001-1-K
Wheel Spacers, 1.25" Wide, $89 pair, 140002-1-K
Wheel Spacers, 1.50" Wide, $89 pair, 140003-1-K
Wheel Spacers, 2.00" Wide, $110 pair, 140004-1-K
Wheel Spacers, 3.00" Wide, $135 pair, 140005-1-K
Starting at: $89.00
Sale: $80.10
Save: 10% off
Available options:
and they change your steering geometery paticularly with wide spaces coz they push your front wheels further out from the pivit on the kingpins
