wheel spacers!
getting ready to order the wheel spacers from Slee and got to thinking today, maybe I'm jumping the gun on problems I may run into, but how do I keep the wheel from moving while tighting the bolts on the spacer, I know I could jam a bar inbetween two of the bolts and hold it that way but I've seen people damage the threads like that! Will the vehicles brakes hold it? Maybe an air gun? any input would be appreciated, thanks! -Ken
If the opposite wheel is firmly on the ground while you install the spacer, you'll have no problem.
You don't have to do anything. You set them on the hub just like a wheel and tighten them up. then you slide the wheel on and you tighten it up. With the rig being fulltime 4wd it doesn't move when you tighten it up especially if you do one at a time.
