Wheel Spacer?
Wa
Would it be ok to use 1in wheel spacer with stock suspension? It's mostly road use.
How long have you had your spacers?
Thanks
If your rig is a DD then why do you need a spacer? I drove it with and without spacers (1,5") and for normal driving there is no difference. But if you really need this because you will feel better or you want the truck to look more aggressive, then there are many factors to consider, such as tire height and width, suspension sag and how much off-road you expect.
I do mild off-road so I fabricated 2 inch spring spacers and even left the stock shocks. It drives excellent with and without spacers. So maybe you could do the same. Make spring spacers and buy wheel spacers.
What size tires? With stock size tires you should be fine. If you're running something larger then you may get some rubbing, either on the front when turning, at the front lower edge of the inner fender liner or on the rear, on the inner side of the flare. The rear rubbing would be likely only if the tire is fully stuffed.
I have been running a set of 1" for 2 years with 35s and 4" lift with no problems other than minor rubbing on the front as described above. I did notice some additional feedback in the steering after installing the spacers as compared to stock. Not really objectionable, just a slight difference that you may feel at first.
R U talking bout "wheel spacers?"....Not spring spacers.
If so i have run mine 1.5" DD for over a year , no problems.
Thanks all. Mine's a DD, little to none offroad. I'm have 285 75 16 tires on stock wheels, stock suspenssion.
Maybe I'll use a 1" spring spcers together with the 1" wheel spacers. What do you guys think?
The thought of the wheel spacer is more for the LOOKS... :D :cool:
Thanks
I use Slee spring spacers up front and front and rear Marlin Crawler wheel spacers and have had no problems on or offfroad.
Be advised wheel spacers can create dangerous handling just when you don't want it - during emergency evasive maneuvers. You'll never know about it until it happens and you're out of control, not something you'll be aware of in everyday driving.
DougM
DougM
No more so than using wheels with less backspacing that factory.
Fred
Same here. Been using my 1.5" wheel spacers for the time I've had my truck (almost 8 months now). I driven about 4k miles on it with lots of driving over bad roads (downtown LA roads filled with potholes and uneven pavement), and my last road trip a couple of weeks ago being 1200 miles of freeway driving around 80mph. I've never had any vibrating issues or camber/toe issues with my alignment so far.
IMO, one of the best mods since it makes the stance of the truck look much better and more aggressive looking.
DougM
Need more details, please explain.
A wider stance should give better handling both on and off road. Harder on vehicle components though.
To piggyback Doug's concern about wheel spacers I have a question for those that run them on their DD.
How often do you recheck the torques? What do you torque the spacers and wheels to?
I've never been crazy about the added stress on knuckles, etc. I wouldn't run spacers unless necessary.
I have 1.5" spacers on my FJ80. I check the torque specs on every oil change (approx 3000 miles). 100 ft/lbs in a star pattern, then same to the wheels.
285/85R16 rubbing on the rear fenders
Hey thanks for this post. Ive got 1993 HDJ81 TD. I had BridgeStone 275/70R16, and just slapped on some BFG AT 285/85R16. All was fine in town, then loaded down began to rub against rear wheel fender - exactly like you say.
What do you recommend?
Please use newbee words, as I don't understand even what a spacer is.
Cheers,
Christopher
