i replaced the wheel bearings in the front left of my 89' 4runner, it's an IFS rig, and the bearings keep coming loose again and again. what could i be doing wrong that allows the bearings to keep coming loose over and over?
I assume there is a star locking ring that is folded over the nuts to stop them from backing off? I am just guessing because I have never been in the front of an IFS setup before aside from helping out a friend on the trail.
you must set the bearing preload, for starters. then install the lock tab. Nat, I disagree with you on replacing the lock washer each time. If you got the money, fine. But there is no reason to do it every time.
Granted if the metal is mangled, or shows signs of creases, replace it.
