wheel arch/flare rubbers part numbers?
Sydney
Hi all,
Does anybody know if there's a different part numbers for different models of 80 series, and for the rear rubbers compared to the front, as the rear has 2 flares, compared to the front which only has one. Amayama seems to think 53851-60021 (discontinued) is the correct front one for my model, but the only part number I see online is 53851-60020-01, which sellers seem to have in packs of 4, but the label says PAD, FR WHEEL. Are they all the same and you just cut 2 of them to suit the rear split sections?
I have a 1994 FZJ80R.
Appreciate any advice/guidance.
Cheers,
Pete
Last I knew you could get white or black. Don’t know if that’s p/n I used but I bought 4 front lefts and cut them, it works. But note the double side tape on the back might not be in the same spot as the correct p/n for the rear
There are a ton of different part numbers for the flare pads depending on flare position, model year and exterior color but I believe not all of them are available anymore. Best to check a parts database with your VIN/spec and then check availability
I've used this front one for all 4 corners and split/cut to length for the rear flares
