Wheel and tire questions for 2010 GX 460
las vegas NV
Hey everyone new owner, I read the wheel and tire forum and have a couple questions hopefully someone can answer.
2010 GX 460 No lift
I want to fit 265/70r17 BFGKo2 on 17x8.5 wheels with 0 offset, is anyone running this set up? I’ve heard minimal body mods like heat gunning one of the bolts may be required and that is easy, but will the size tire and wheel have full range of motion with my stock height? Thanks
my info may be close.....but not a cigar
I did a 2" lift at the same time I added 17's..LT265-70x17
Wheels are the same..but with a +7 offset....5" BS
KO2's were my second choice....the Goodyear AT's won out
They still have a very minor rub at full lock...no biggie for me
Car is an '11 GX 460 (PS...spare didn't fit under)
When you say you get a little rub at full lock, is that under compression? Or just a parking lot lock-to-lock?
If it's just on flat ground, your rubbing will be much worst if you're off camber with a fully compressed wheel stuffed in your wheel well and you're trying to turn your steering wheel.
