what's this?
Val-David
I see a lot of fj-40 with the running boards removed and a black piece of metal (?)
screwed on the rocker panels. Are they custom made or can you buy them somewhere?
Thanks :beer:
thanks for your help. Time to use the sawsall :D
Hi All:
I made some simple heavy-duty side steps to replace the easily mangled stock running boards.
I used 1/4 inch thick 4 inch by 4 inch "angle iron." Cut the metal to conform to the general shape of the stock side step, and used the mounting holes on the stock step as a temp plate for drilling mounting holes on the heavy-duty side step.
These side steps maintain a "stockish" look for the truck, and are stout enough that one can pivot the truck on a tree stump without damage.
If you search for threads I've started in this section you will find pics of my rig (blue) and a buddies (green) with similar custom side steps.
Good luck!
Alan
Seattle
