In starting to get my FJ40 ready to haul out to Cruise Moab, I did a Combustion Leak check (Lisle blue water thingy) and found I have leaks in #3 and #4. I suspect a bad head gasket between/near #3 and #4, but before I pull the head and replace it, any other thoughts? I did a quick compression check and got 155, 150, 138, 138, 148, 155. The only real symptom I had was occasionally I'd overflow the overflow bottle after shutdown - it would sputter and spit!
Here are what the plugs looked like when I pulled them:
History of the engine: Its the original 2F in my 75 FJ40. I seized it back in Sept '01 and then rebuilt it - new bearings, new crankshaft from Mark Whatley, milled head, new valves, stems, rockers, etc. The cylinders were okay and so I only had them honed, but I added new pistons. I used the rebuild kit from PacLift. Most of that reassembly was done in late '01/early '02. The motor, however, was not ever filled with fluids or turned over until about Jan/Feb of last year! The engine probably has about 400-500 miles on it since the rebuild.
I'm hoping/thinking that the head gasket probably had just dried out and gotten compromised. Any other thoughts and/or anything else to check before I pull the head?
Thanks!
Thanks!
