What's magical about the Carolla Washer bottle?
I have been searching the archives to learn as much as possible about designing a dual battery system
Since I am the hopeful type, it seems to me I might was well do the Corolla-washer-bottle-mod just in case someday providence grants me the opportunity to install a super charger. (why move the bottle twice?)
Several threads have called out p/n 85331-12690. My local dealer tells me that was ONE of the washer bottles in the Corolla during 1988 - 1992. This weekend I stopped by a local crushing yard. Found a Corolla with a manufacture date of 12/89, assumed that was probably 1990 model year, and $4 later I had my trophy in the FJ40 and I was heading home dreaming of dual bats & a SC in the FZJ80.
The bottle does not have a ten digit part number stamped on it (p/n 060351-448). But REALLY ! I am making my own bracket! It only holds water !
WHAT IS IT ABOUT THE COROLLA BOTTLE THAT HELPS WITH THIS MOD?
If this bottle will do that, who cares about the p/n?
If you make your own bracket just use the OEM washer bottle and mount it like the Slee setup. You will need to splice and lengthen the wires to move it back there.
I just found a GM one that was sitting on the ground at the local pick and pull with the pump and part of the harness still hanging on . so for a $1 I wired it up and made a bracket .
Works well but I have no clue what it came out of other then a newer GM of some sort (had a 2003 date stamped on it )
