whats cowl vent for?
It's for ventilation for your feet when they get hot from the 3 speed tranny under your feet. If you insulate well, you should be fine. :D
You need it. It's your 40's internal hydration system intake, necessary for rust propagation. :D
Seriously, it's an air vent installed on earlier models (not sure of the span, but the '66 I had used a vent mech. in the windshield. My '67 has the operational cowl vent and my '75 has a vestigal cowl vent). They're notorious water-entry points if the seals/mechanism/drain tubes aren't in good shape, so lotsa folks just seal the vent with a solid cover ala SOR.
Not really necessary IMO with the kick vents so close at hand, but I liked the cool factor and repaired the vent on my '67...no leaks now.
thx for the input , ill probly seal that off then . i like the way it looks with the vent tho so maybe i'll plug it and put a vent on it for looks.
It's a catch pit for leaves and june-bugs.........
