what year make model trucks cars can i use fuel tank from for a 86 4runner
baltimore
Website
www.monsterfishkeepers.com
Trying to figure out why my truck running like crap decided top pull fuel pump assembly out. THe guage wasnt working so had to anyway. Well long story short i cracked the realy rusty high pressure line befor the fitting but after it comes out the top of the tank. And the rest of that high pressure line looks like its ready to go as soon as i think of moving it. or trying to get the nuts lose. So what other trucks or cars can i yank the whole fuel tank assembly and use it in my 86 4runner with a 22 re.
23206-35121, looks like Truck/4Runner only part. Even if you find one in a junkyard, it will also be rusty and won't be worth the trouble to swap it. Just get a new one, should be ~$100 from Sam.
i need everything not just the pump. my high pressure line coming out the top the plate cracked. and the lines to rusty to unbolt the rubber line from it.
sam cant get the lines there discontinued. Im gonna have to run a external fuel pump. or flair the high pressure line coming out the tank. and run a rubber line to the front. I just gota figure out wich way i wana do it. I got a custom hose place localy. Might be able to get a fiting to place on the metal line coming from my tank. flair that line so fiting dont come off and get custom line made with the right fittings on each ends.
Do a search on pirate 4x4. You can do a fuel tank from a ford between the frame rails in the back if ya want to.
so if u had a 22re truck. and cracked the high pressure fuel line after it comes out the tank and u think u have enuf tube left to atach a fiting or a hose to it. How would u do it without it A blowing said hose off because i figure 44 psi would be to much pressure? also how would u conect to the fuel filter in the front of the truck so u can get the fuel to the motor. Pretty shore ima have to run everything new from outside the tank to the filter under the hood.
