What winch size?
South Africa
Went 4x4ing on saterday and found my 8000lbs Warn to weak to pull my rig.Even with my snatch block.The winch is new and has done little to no work.Is this winch to small for my 80?:o
Used both my hilux winches many times with out problems.
In heavy to hard winching.But my new hilux is light in the pants.
Starting to think 8000lbs is to small for cruiser.:doh:
If I understand correctly, 8000 is only the capacity for the first layer on the drum. So unless your cable was pulled all the way out, you had less than 8000 pound capacity. Maybe that's the problem?
We use a Warn M12000 on our 80 with lots of stuff-armor, bumper, etc. Works great!
Yes. A mildly equipped 80 with fuel and supplies can easily tip the scale at 7K lbs. The use of a snatch block is a luxury and should not be considered when properly sizing a winch for recovery.
I have a Superwinch x9, 9000lb, and had no problems when up to the bumpers in mud.
Paul
