What to grease?? Need Help
Hi everybody..
I have greased my car FZJ71L.....
The shaft, joint and the two points of the rod, steering tie.
But I have heard about greasing the wheel bearing.
Where can I find these points?
Here are some pictures,,,
And you can see the grease of the steering..
How to grease the Hub and the wheel bearing??
Note: I used NLGI No.2
Thanks for reading...
Hello,
You would have to take apart the wheel hub to grease it.
Newer (post 1999) models have fewer greasing ports than older models.
From the photographs, it would be good for you to disassemble the wheel hubs and grease them.
Juan
There is no way you can grease the hub ant wheel bearing without dismantling it.:D:bang:
Thank you.
Hello,
Juan
Thanks Juan. I'll keep that in mind.
See in top of your photo there is a big square nut unscrew and check grease level there
Thank you but I didn't get it..
Here is the picture..
Use Moly grease in the knuckle, do not use a grease that is not moly fortified and don't mix greases that use a different soap to make the grease (ie: don't mix a Lithium grease with a Bentone grease for example).
~John
