What to do about brake problems
Hiding
Uhh. Well I went two steps back this weekend with the brakes. This is a 1977 Front and Rear Axle. I am replacing all of the hard lines with new ones I am bending myself.
It appears that one of the wheel cylinders. Passenger rear most. has a problem with the brake fitting.
I can run the new fitting all the way down into the cylinder and it wont "lock up" the brake line. There is still Play which is leaking fluid.
Does this mean I need a new wheel cylinder?
I tried two different new lines. and the original and all have the same problem.
Thanks Warren.
you double flared the new lines, not single flare?
there are some longer-threaded fittings, some with a longer "nose"....believe I've always gotten mine at NAPA, might be worth a stop to see what they have....some of mine have about 3/4" of thread avail...
Yeah, I learned the hard way with that . Luckily it was only a few bucks. I did get my lines at napa, since they were the only ones that had the lines with the "nose" These new lines look EXACTLY the same as the old lines. only that they are 11mm instead of 10mm. These napa lines work just fine with no problem everywhere else on the truck. So it is just the wheel cylinder that is giving me problems.
The bleeder screw hole and the brake line hole are the same diameter, but with different bottoms. Are you 100 percent sure you have the line in the right hole?
Oooohhh I thought about that, I am not sure 100% but I can tell you that I am attempting to screw in the brake line to the rear most hole on the rearmost cylidner on the passenger side rear. The next hole to that (next to axle tube) has the "jumper line" going from it to the inside hole of the front cylidner. Then the forward most hole has the bleeder screw in it.
This is the way it was hooked up on my 1975 axles. Also The Driver side is set up the same way with the same lines with out issue. Should I move the bleeder screw. Does it matter on the rears which cylinder has the bleeder?
Thanks
ding , ding , ding , bleeder screw should be out back , or someone may have put wheel cyl. on wrong , which way are the adjusters pointing , in respect to front and rear w/c ????
Sorry I was out on Vacation.
There were no lines befoe, These are axles I rebuilt, So I am the dumb ass PO that screwed them up. I love doing stuff more than once.
So the bleeders are out back on both sides?
Does anyone have a photo of the stock location/ position of the hard lines they could post up. I would love to get at least the rear brakes working this weekend.
Thanks.
