what to check inside 4sp?
land of enchantment, at least for now
I have a '74 4speed on the shop floor. Before I put it back in the rig it came from, are there definitive ways to check it's condition without disassembling it or driving it?
It came out of an fj with a bad motor so I've never driven it. When I drained the oils, the tcase oil looked pretty clean and maybe recent. The tranny oil was much darker and seemed to have a lot of sparkle to it. The drain plug had *a lot* of metal on it, but nothing bigger than the typical tiny shavings. I pulled the top off and everything looks good, but there is visible wear (a groove) on the 3-4 shift fork, on the front side like the driver rested his had on the shifter while he drove.
Looking at the chassis manual, I wasn't sure what measurements I could do with the tranny assembled, aside from measuring shift fork to collar tolerance, which obviously is beyond spec.
Not really. In fact, you can't be sure even after disassembling it. If you want to be sure, you put new parts in it. You can measure the clearance between the synchro rings to see how much wear they have, but it might work just fine with them worn beyond specs and this isn't going to tell you everything you want to know.
Put it in any you will find out if you are lucky or not.
