Hi, anyone confirm that the intake manifold plug on a 1980 FJ40 is a 16mm fine thread size.
Planning to install a vacuum gauge and need a screw in hose barb or adapter.
Thanks much
I have 3 different sizes of BSPT brass barbs-I'll check to see the overall size at the tip of the threads--
here they are---
The plug that came out of my 77 oem manifold is shown in the last pic-along with the third BSPT barb
The plug is around 5/8 or 16mm but I will mic it later to give you a better idea. Kind of thought that there may be a few different sizes.
That out of the 77 plug looks to be a bolt type. Hum- Went to a hardware store to use the thread seizer they have and on the metric side it was close to 16mm but would not screw in the fine or cores thread size.
Checked the non metric and close to 5/8" but would not fit either thread type also??
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
