What the crap is missing here?
Santa Rosa beach, Fl
So I was installing a new starter this evening and as I lay, covered in grease and grime, ready to curse the Toyota gods for devising every way possible to keep my wrench from turning, I look up and see this.
I imagine that seeing the gears in what I assume is my center differential is not a good thing and since I haven't leaked any significant fluid since I've owned it and it's driving fine, I can assume that it's not the end of the world.
Can anyone here offer any form of comment on what the heck I'm looking at and where I should go from here. I have no need to lock the center diff. But one day I might and even if I don't I surely don't want to leave it like this.
Thanks all.
Looks like the flywheel. If it is, there's a little black rubber/plastic cover that goes there.
I don't see any bolts where your cover is stretch. Are we looking at the same thing? Looks like mine requires two bolts on either side to hold it in place. I can't imagine having the flywheel exposed is a good thing right?
It's the same thing except mine has studs and yours has a bolt going through. Might be a different year design thing. Mine is a '94. I agree it can be a good thing to have the flywheel exposed the way it is.
Is that a 3FE? Because the 93 and later ones have a plastic snap in cover facing forward. Mine was missing too, btw.
Was...sounds like you may have pilaged sourced a replacement from a certain cruiser I know...:rolleyes:
Called the dealer and ordered the part. They will be sending it out from cali should be here next week. Wish I knew someone local I could pillage from, but I don't know anyone in the FL panhandle with an old cruiser besides myself.
