And these are the smaller ones correct?Those are not flange nuts. You really want flange nuts. I generally recommend 90179-08023. These have really nice serrations on the backside of the flange portion of the nut. Lock it into the fan clutch base.
Interesting. I pulled mine off and it had bolts instead of nuts. I wonder if it was changed at some pointThere are only one size nut for OEM fan clutches for the 1FZ-FE: M8x1.25
My apologies. I got confused and thought this was for the fan blade to clutch nuts. But I am still trying to find the correct pn for the blade to clutch nuts for the blue hub clutch.No. Toyota does not use bolts for fan clutches. Studs with nuts.
Ok thanks! These were the ones partsouq had on the schematic. These should at least be a bit better for me. The previous owner left me with mismatched sizes.Those are not flange nuts. You really want flange nuts. I generally recommend 90179-08123. These have really nice serrations on the backside of the flange portion of the nut. Lock it into the fan clutch base.
