I had to cut mine off due to the bolt seizing itself to the UCA bushing inner sleeve
. If anyone knows the size, that'd be great. The factory bolt that this bolt replaced is a 17mm but I can't find that diam bolt anywhere for sale. So, then I tried 11/16" bolt and that doesn't exist either. The ID of the UCA bushing sleeve is 18.17mm. The OD of the factory bolt that normally lives there is 16.95mm.
Using a 5/8" bolt seems like there'd too much play. I've sent Dave from Delta V an inquiry as well.
. If anyone knows the size, that'd be great. The factory bolt that this bolt replaced is a 17mm but I can't find that diam bolt anywhere for sale. So, then I tried 11/16" bolt and that doesn't exist either. The ID of the UCA bushing sleeve is 18.17mm. The OD of the factory bolt that normally lives there is 16.95mm.Using a 5/8" bolt seems like there'd too much play. I've sent Dave from Delta V an inquiry as well.
