What part number?
They ended up canceling my second order, citing out of stock. So I just went to the local salvage yard and pulled one off a Sequoia. Seems to have fixed the issue.
Has anyone been able to find this part online recently? I cannot locate the replacement for valve 2, part number 25860-50150. I need to replace 90910-12261 which I believe was superseded by 25860-50150. Any suggestions as this part showing out of stock in the US. Thank you in advance.
Curious what year Sequoia you pulled this from? Any issues since you fixed it? Was it the same part number? I am trying to find the same part. Thanks in advance.
I pulled it off an 03 Sequoia. The 25860-50150 has now been discontinued. They say it has been replaced by 90910-12130, but that part doesn't look right either. I'll be calling my toyota parts rep to see what they can turn up.
Let me know if you find a new part number. I am in the same boat of needing this part but can't find it available.
I don't know if this is the same, but it looks like the same part. The first gen sequoia part number: 90910-12246
Ordered one from Impex, $20. Will update everyone when it arrives.
Can confirm that 90910-12246 is the exact replacement for the discontinued part.
Didn’t install, as I’m waiting to do this with new charcoal canister, but it is a direct match
Installed and functional. It didn't come with the lower bracket, so you will reuse the original.
That's because the part number you all have been searching or isn't the service part number. The EPC lists the part number as 25860-50160, which is the valve assembly: the valve and the bracket. It's still in US dealer warehouse stock, although at $107, it's far more expensive than the valve only which Impex lists for $19.
I think people pass over that as it’s not positioned the same way, and most toyota sites will list it as not compatible. 50150 was the LC specific that has been discontinued.
I was perfectly fine paying $19 and reusing the bracket. $80-90 markup for a bracket is wild.
I do not blame you one bit.
