What part is this?
After driving for about 3 miles from home today I started seeing the temp' needle heading to the red, and steam coming from the hood. I pulled over , pop the hood and saw this busted hose to the rear of the engine. After 15 minutes, temp was back to norm and I drove back home. So I need to replace it and not sure what part to ask for.
TIA
Your pic shows nearly all of the heater hoses, I can't tell which one you are referring to. And that's what you should replace- all of them, and probably the heater valve as well, which is in the middle of the cluster of hoses above the valve cover. Get the PHH, intake, and all radiator hoses at the same time.
Here it is..
I'd replace all of them. But any way, that specific hose is 87245-60340.
Clamps: 96112-10250
Have a handy P/N list of “all” of them? :)
Finally got around to taking a look at the truck. To my surprise I see a bypass instead of the part mentioned above. I had call cruiserdan # a few weeks ago to order it, but the guy I spoke with advised me that with shipping it be cheaper to get it at the dealer. Never did get around to it, anyways here r pics of the bypass. This engine was installed a year ago and my mechanic did call me and asked if I needed heat in the rear since the lines were rusted. I told him that it was okay to bypass it so I'm not sure if this is related. The bypass rubber was cracked so I replaced it with a new one I picked up for the auto store.
Now is it ok to have this bypass?
Just remove that T and the old hoses and replace with a straight section of standard 5/8" heater hose.
dsc_6324-jpg.923172
(Not my pic, just found on google)
