what is this
la minerve, quebec,canada
it shoud be leaking something out of this .do somebody knows what it is for please
Power steering cooler.
That's the 10,000 question,,,lol. Could be quite a few things,,, possible leaking radiator coil,,,, which can leak transmission fluid as well, due to the exchanger inside the radiator for the transmission fluid to pre heat on cold starts. You also have the transmission cooler coil , mounted in front of the radiator,,,,,,,,,Does it smell like coolant , oil , transmission fluid? Put a big spot lite in there and start it up , I am sure it will show itself,, narrowing down the smell of the fluid, will help more to the exact Areas to look at .
CRUISER CARTEL
Possibly by road debris, previous owner fixed it on the fly and figured no big deal to bypass powersteering cooler...
you can see that is it broken,, but nothing is leaking and these no fluid missing anywhere ,so the previous onwer cancel the power steering cooler i think
I pinched mine on a trail when I hit it on something. It wasn't leaking so I ignored it for a while. Now I know what it is. Thanks for the info.
Mine cooler is pinched closed, doesn't look like it could flow anymore. Will this affect the power steering pump or cause a back pressure?
