what is this?
Val-David
I'd like to know what was the function of this unplugged hose on a 1971 F engine? It was probably removed by the P.O. when he changed to a desmogged 2F .
Thanks!
Are you sure? I thought It was going to the carb insulator???
Not PVC. On a 71, the PVC hose connects to the plenum under the carb.
It is part of the engine modification system and connects to the fuel vapor storage case in those vehicles so equipped. This is a figure from the 1971 Emission control manual. I plugged mine.
Thanks ! I will plug mine too. And BTW, do I realy need a pcv valve on a desmogged engine, because I don't have anything where it should be...
YES you want the PCV.
what is the difference between letting it exhaust by the side cover ,or going back to the carb?
The difference is crank case gases will be pulled out by the vacuum of the engine if connected, and burned, or they will end up all over everything under the hood... Your choice... :D
Its "positive" crankcase ventilation. which means you need air forceably moved through the motor. One side needs clean air(connected to air cleaner) Other side to constant vacuum(under carb) Other wise you get a unhealthy buidup of gasses in the motor. Then blown gaskets, poor performance....
Coolerman :The difference is crank case gases will be pulled out by the vacuum of the engine if connected, and burned, or they will end up all over everything under the hood... Your choice...
You made me understand something :whoops: That's the sh*it I have all over my paint :doh:
There will be a pcv this week!
Thanks ! you guys are great :bounce:
This thread helped me figure out why there was a hose running from the side of my head to under my carb. Now I guess when I put my aircleaner on, the pipe coming from the back of cleaner will need to be connected to the pipe on the top of the crank case cover at the back. Exactly were do you put pcv at? Inline with the clean air line or the vaccum line?
Thanks guys, I didn't mean to hijack or anything, just trying to learn a little extra.;)
Jeremy
HTH
