What is this?
Lawrenceville GA
I was checking all my fluids today and just doing a look around when I see this cable coming out of the fire wall near the PHH. Anyone know what it's for or where it should be attached? Cruiser seems to be running fine otherwise.
Looks like the heater valve control tensioner, should connect to the water valve in the picture, slides when moving the heater controls on the interior to allow more or less flow
What he said
Check you heater control valve that is bolted to the firewall right above the head. There should be a cable attached to control the volume of coolant flowing to the heater core...if that cable is missing then that is most likely your mystery cable.
While you’re in there rewrap that wiring harness with new high temp material.
That egr pipe can melt the wires and cause all sorts of problems
Agreed with the replacement. When they start browning its normally a sign the plastic is beginning to fail.
