What is the thing called...?
open the hood and start checking vac hoses in the middle on the firewall.if they are hooked up start tracing those hoses to the front end,while checking for cracks etc. they are really simple to work on.you should not hear air i dont believe which leads me to believe that you have a leak.but the newest rig i had that had vac shift was a 71 so im sure you will hear some more feedback.the valve is a dull silver also check to see if thats working
What is that splitter thing called that engages the front axle? Mine isn't working. I had a '65 LC and I could hear the air "psssstt" when ever I engaged or disengaged the front axle. Today I tried my latest project LC and the front wouldn't engage.
The vaccuum transfer shift valve?
ok now take the hose that locks the front end itself run it to the manifold and see if the front end locks in itself.im sure you will have to add some hose or rig something up.then we can go from there:Dbut im sure its the valve
I have an extra one from my '69 parts rig, hopefully it's good. Are these rebuildable?
im not sure.but i did have one go out on me in the middle of nowhere.:o it a had a mudmasons nest in it somehow.slap the extra in if no go try hooking the line direct to the manifold.ive never had much trouble out of them
They are, but you may play hell finding the parts. Tim Hill says he has the rebuild kits.
BTW, I just removed all mine last night, and went with a floor shift rig. Mine worked well, but I couldn't put a dual battery box in with it on the firewall.
yep on the 71 dad later on did the same.i also really did not like the fact the shift linkage could leave you hanging in the woods
Where did you get the floor shift set up? I by-passed the valve and went straight to the transfer and still nothing. I know the hubs are working because I turned the driveshaft then locked the hubs and could no longer turn the driveshaft.
Remove the two hoses that are attached to the controller on the tcase, and remove the four bolts that attach it to the nose cone and work on it on a bench. You may find a bellows that is dry rotted, or corrosion on the linkage keeping it from moving.
These are a pretty simple device to work on.
Good luck!
-Steve
Good luck!
-Steve
I'm going to remove the controler today, if the bellows are torn, is there a way to fix it? Is there a kit?
