What is missing from the window switch area which is loose?
San francisco
pictures attached
I see the piece at the in the incide of it is broken, a clip which from the glue it appears that it was broken already and someone attached it.
I looked inside the door and it appeared that it didnt break and fall inside the door panel.
Is there a cheaper fix than buying the while window switch panel
or is there a way to make is tighter/stick so that it wont slide and move about
Not sure on a MacGyver fix, but You should only need the plastic piece that surrounds the window control switches, not the actual switch assembly
I think there may be someone that has 3D printed those parts, maybe look into the 3d printing threads for that.
