So I am planning my next steps for working on the lc. It is a 97 and after purchasing it, I replaced the head gasket. After several attempts of troubleshooting and still no start, I am going back through the pictures I took when disassembling. Came across this picture of a wire I forgot I unbolted from the head. Apparently I knew I would forget it and took a picture pointing to. Can someone tell me what this goes to? I have looked through the ewd and searched the forum for this with no luck. Thanks!
The picture location is of cylinder 6 exhaust port. The wire is further back on the head than the ground strap that connects the head to the firewall.
the picture makes it look like a wire. On a better note, found another problem. The damper is twisted and this is what is likely the cause of my no start condition. Looks like someone tried to hold this while breaking the crank bolt loose or something. Before disassembly, I snapped a picture after noticing the rubber material was coming out a little bit. This also explains why after the rebuild the piston travels up a few mm after tdc on the damper. Didn't tie this to timing until a few hours ago... New one ordered and hopefully starting soon
