What does this part do?
Anaheim, CA
Went out on a trail yesterday and after hitting a mud puddle the truck wasn’t running good. A few warning lights were on. For instance the voltage was sitting lower than normal at the midway mark, the A/T Oil Temp light was on, the oil symbol was lit up, and one other light was on.
Long story short the alternator wasn’t charging the battery. Been doing a bunch of research on Mud for 24 hours and been trouble shooting it. I know the alternator is toast but just wanted to make sure there isn’t any broken or loose connections too.
I found a wire nearly broken off of this gray connector and decided to eliminate the connector and solder it to the battery terminal since that’s where it ends up anyway. I’m worried that this connector is more than just a connector. Does anyone know if it drops the voltage or does anything other than connecting the 2 wires together? It normally sits at the same location as the positive terminal connector box.
The alternator can be easy rebuilt with new brushes and regulator if you need it that plug looks like the plug to the alternator, it is a common used plug in nearly every Toyota vehicles
Thanks Shock. So you don’t think it does anything other than connect the wires?
I’m thinking I’ve seen that connector over on the DR side wheelwell area behind the battery - if nobody’s got an answer for you I gotta toss the trickle charger on mine tomorrow anyhow, so I’ll see if I am right that the wire went to something under the intake manifold.
He says it originally attached to the battery so I am pretty sure it is a fusible link. I can't think of any other small wires that attach to the battery.
Sorry guys I didn’t know what a fusible link was. I educated myself on them now. Thanks everyone.
