I can't see it in the FSM anywhere. What does the sensor sense? I hear it is a ring on the crank from searching through posts. Can I use the ring off of my 97 on a 93? Or do I need the 97 crank? A pic would be most helpful. The plan is to use a 93 motor, rebuild it, and put it in the LX450.
thanks
A lot of the laws pertaining to engine swaps are federal.. where the engine you pace in the vehicle must be same year or later.. and that has to do with emissions being the same or better than what you took out.
No emissions requirements up here in my county. I think there are down in Denver. Not too worried about the feds checking my motor and I never sell anything for some reason. Anyway, it sounds like I don't have to remove the crank itself to upgrade the position sensor stuff, excellent. I'm still weighing the cost of purchasing a low mileage 96, or purchasing a 93 builder. Feels like a roll of the dice either way. About $2000 for the 96 w/ 129,000 miles, good compression and oil pressure. A 93 builder plus machine work, provided there ain't a lot of crank regrind or new pistons, is about the same. Either one gets a head gasket plus the same upgrades essentially.
the oil pump is part of the front timing cover and identical on all years of 1FZ-FEs. The drive gears are different because of the index ring on the later models.
thanks
I pulled the beasts guts out today, finally. Separated the tranny and almost got to the front pulley but couldn't find that socket. That's one bad arss oil pan, wow. It's like half the motor. And never will I pull another motor without a leveller. It's really hard to hold that thing up and adjust a link or two. And another thing, that lift and those big tires, not helpful at this moment. I wish my crank level was higher right now.
I reread the thread and couldn't figure out if what the sensor senses is any different between different engines, i.e. the ring drive shaft.
I can see between the 3F and 1FZ series, assuming different cranks, but is it otherwise only a matter of using the right year sensor within the series? Is that why landtank had to swap to go from 93 to 96 or am I just confused?
Not that I ever want to have to pull a LC motor, mind you, just curious. Them are some real boat anchors!
the 93 and 94 engines don't have a crank sensor. So if you want to use one for a core for a 95+ truck you need to alter the engine by installing the crank sensor parts.
thanks
The actual use of the CPS is to allow the computer to read the RPMs of the crankshaft and allow to adjust timing and fuel rate for the engine to perform at optimum rate.
I don't know how the cranks on the 93 and the 97 compare but if you're planning on using the 97 computer it's going to need a signal from the cps.
