What does it take to do a conversion on the engine.
Mikesta
Never decruiserfied
Missouri
Website
www.showmerents.com
Looking to do a f to 2f swap. What should I watch out for? If there is already a thread on this that you know about please send me the link.
Thanks!
Had to change motor mounts, and exhaust on mine. Everything else pretty much swapped over. Stayed with stock 3 spd tranny, bolted right to it. Went from F to 2F in January. Very happy with it.
Thats what I was wanting to hear! Thanks Todd!
I wouldnt go so far as to say everything swaps over... Lots of little things can catch up with you. are you planning on swaping only the longblock and keeping everything else "F" motor? or are you going to leave 2F brackets, carb intake etc?
Be aware that 2F motor mounts brackets on the block have larger holes.
I said I changed my motor mounts...
Also swapped a 32/36 Webber for a 38 - but didn't have to.
Changed ignition from stock points and rotor to DUI - but didn't have to.
Changed radiator fan - probably did have to, but minor.
Changed water pump - but didn't have to.
Respositioned remote Oil filter bracket from driver's side on F to passenger side on 2F.
Installed oil cooler, headers, fluid heat riser - more for performance than necessity.
I changed a lot of things, because it was a good time to do it, but not absolutely necessary.
I dont know what Im planning... hope I can figure out what to do with data collected from this thread. Any advice or wisdom greatly appreciated.
my 67 fj45 long bed has a 77 2F in it, came that way though......come look at it when you check out the 45 wagon :)
Im going to bring a tent... it will take a while to look at all your cruisers!
I put a (mostly) 2F in my '74 Pig last summer. Used the 2F alternator mount and had to shorten some wires. Also, the oil pressure sender hole (same place as the F) didn't get any oil, had to add an oil cooler to get the pressure sender mounted.
