- Joined
- Oct 21, 2006
- Threads
- 12
- Messages
- 30
So I found another 4Rnr on Craigslist...
http://milwaukee.craigslist.org/car/302712480.html
Called the kid up, asked a few questions, forgot to ask a few, but the jist of what I do know about it is...
-1986 4Rnr
-22re motor
-152,xxx miles
-shifts fine *
-4wd engages/operates smoothly **
-idles/run fine ***
-stock suspension
-32" tires
-steering is fine - big tires rub at full lock (no lift, old springs, no sh*t)
-clutch is a little soft from the start, but seems to work better after being used a bit
I don't know how much rust is on the body/frame. Obviously a little is fine, but tons of rust/rot is no good (at least for me.) Don't know how the brakes are, if the exhaust is decent, how the vehicle heats up. This thing will be more of a daily driver for a while, so tons of work needing to be done is really not desirable for me. Now my questions for you all...
* - He said when in Reverse, it really chugs and runs poorly (but only at lower speeds. Up the RPM's and it works better). I thought idle was perhaps low, but that would affect forward gears as well, and those seem to be ok. Would there be anything, other than tranny issues, that would make a vehicle work poorly in Reverse but not in the forward gears?
** - He said he can "hear the driveshaft." To me that sounds like u-joint problems. If it is, no biggie, I can replace those. But what else would make a person hear a driveshaft??
*** - He said he recently turned down the idle speed because it was running a little high. Now in my experience, when idle speed needs adjusting, it's either because something needs attending to, or something else was done to the motor to necessitate a change. Thoughts?
Obviously, being able to look at the truck in person and give a little test drive will provide some more insight, but I'm really strapped for dough right now, and if this truck really isn't worth what he's asking, I'd like to know so I can either offer less, or pass it up.
I appreciate any and all responses, because I really want a decent platform to start my replacement with.
Thanks all.
-Chris
-1986 4Rnr
-22re motor
-152,xxx miles
-shifts fine *
-idles/run fine ***
-stock suspension
-32" tires
Thanks all.
-Chris
