What causes burnt-out points?
Dallas, TX
I finally got around to replacing the electronic ignition in my '76 FJ 40 with an OEM distributor. Why would I do that? Because the PO put a Corolla electronic ignition in. It had intermittant problems, but nothing too serious. I had the guy that does some of work on my rig put in an OEM unit. Everything worked fine, and I drove it to the Roundup and back with no problems. Then last week it started having starting problems, and Saturday I got stranded when I jumped in and it wouldn't start to save my life. Turned over fine. Just no spark.
To his credit the guy that put it in came to the parking lot I left it in and put in a new set of points. I asked him what caused the problem and he said something about a short, but there was a bit of a problem with communication as he's Vietnamese. The old ones are burnt to a bluish color. Now I'm kind of gun shy. I got stranded less than a mile from home, but I'd hate to be marooned a hundred miles from my house.
Questions: What causes the points to be burnt like that? What does it cost to put a proper aftermarket electronic ignition in? What parts are replaced and which ones stay? Do you leave the distributor in and just swap in the electronic parts, or what?
Bad condensor.
So where can I get a new one? He had trouble finding the one he put on there. I wish I had a pic. It has a 4" long piece of porcelain attached to it with a couple of brass electrical connectors on it. So again, how involved a project is it to put in an electronic ignition?
What kind of spark plugs are you using? If you are using american plugs they will burn out a lot quicker than the toyota ones. I am talking from experience. The first time I replaced them I used american ones, within a month the cruiser would turn and turn but wouldn't fireup. Pulled the plugs and they were black and corroded. Went to my man at toyota, part of the cruiser club, and very knowledgable. He informed me that american plugs won't work in a cruiser. Bought a set of the toyota plugs and have never looked back. Hope that helps
as easy as swapping the distributor, side plate, and coil+ignitor off of an 81-87 cruiser, and doing a little wiring. (very little) To take full advantage of this dist. you need to port your carb for vac advance. If you can swap a dizzy, the whole deal should take just a few hours one saturday afternoon. Cleaning the old side plate gasket is the most time consuming part.
Paulj based on your last post are you looking for a new condensor or a new ballast resistor??? I can't tell for sure. The big porcelain piece you mention is the ballast resistor. Treeroot, cruiserbrett, and ranger have correctly listed the three things that will cause your points to go south....and Bailey covers the full electronic swap above. The cheapest way to get the cruiser moving again is to put a set of points and condensor in it, with the ballast in line. If it runs your done. If not, you may need the 12 volt start up only wire. If it starts then immediately dies with the 12v start up only wire, then take the ballast resistor off line and you can remove the 12 volt start only wire at that point as well. As your coil is most likely internally resisted, hence thats why it'll die with a duplicate ballast resistor hooked up in series. Keep a spare set of points and condensor in the glove box and your good to go.
ranger said:
More than likely it is a bad condenser. Every time you change out points, you must also change the condenser.
This and also having either a coil with an internal resistor or an external resistor with a regular coil. I burned through points and condensors for a whole summer before I got on here and found out about the resistor. Drove me nuts.
Hey Paul, I'm about to throw in the Pertronix unit into my current distributor ( a brand spankin new Toyota non USA unit with dial on it to adjust timing.) You can put the pertronix in any dizzy to eliminate points; essentially making it electronic. Usually you get a slightly hotter coil with internal ballast resistor at the same time. I hear GREAT things about this unit, both reliability and longevity. And its cheap. I also have eliminated my igniter; now less stuff to go wrong but you have to run a little conderser either inside the dizzy or mounted ouside the dizzy body. Wish I had caught up with you on Saturday at the Roundup but I was busy dealing with my first MAJOR CARNAGE: a broken motor mount and resulting in engine shift/holes in the radiator and header.
I'm not sure what I'm looking for at this point. I'm not very mechanically inclined. I'm more of a parts changer, but I guess I'm learning more and doing more the longer I own my Cruiser. All I know is I've got a new distributor and a new coil with a big porcelain thing attached to the outside of it. I guess I've got a new condenser too. Where is that located? Can some one explain what exactly the condensor, coil, and ballast resistor do?
We are all parts changers....lets take an alternator for example. If you don't replace the whole assembly, you rebuild it. Rebuilding it is nothing more than changing out the little parts inside. :)
Restoration, for the most part, is replacing rusty parts with nice shiny painted parts.
That reminds me of a Monty Python skit I once saw. They made up a TV show called "How to Do It" where one of them demonstrated, "How to Play the Flute".
"You put this end up to your lips and blow, and then move the keys up and down with your fingers."
