what backspacing for a 97?
Harrisonburg, VA
the ol' lady just got another cruiser and wants black steelies. I had trouble finding the correct bs when i got rockcrawlers for my tacoma, the set i was sent that was suppose to fit didn't. The 80 has stock 16x7.5 correct. I'd like to go with 16x8 for hers, what is the correct bs? also, whats the lug pattern? thanks
Just an FYI, this has been discussed a lot. You could search out backspace and pull a lot of threads.
That being said, stock is 4.5" and that is what I'm running with my 16x8s and 315s. This BS will clear the flares. Personally, I no longer have flares, so I will be moving to a 3" - 3.25" BS here soon. HTH!
sorry, i figured this had been beat to death, i was searching "backspacing" no wonder i wasn't finding anything
she took my 40, i bought a 60...she took that, i bought her a 60...she bought an 80, now i have my 60 back, somehow i still feel shafted. now i have to fix up her 80.
Lug pattern is 6 on 5.5. You have to change your lugnuts if you go to black steelies.
I assume that is b/c it has lugs like my tacoma? Make you a deal, you find a pristine maroon 80 and she'll trade you her antique sage, collectors, pristine 56K. She really wanted maroon
If you have conical lugnuts then it should work but check with the vendor. I decided to go to black aftermarket ones. Does her 80 have lockers?
more important that BS is offset. Our trucks have wheels with 0 offset. The stock rims are 16 x 8 so that means they are 9" wide, width is measured outside to outside, yielding a 4.5" BS. Now if you got a 16 x 10 rim you would want a BS of 5.5" as that rim is 11" wide.
Landtank, just got the seat extensions by the way...thanks. But, in regards to your comment here, if I got a 16x10 wheel with 3.5" backspacing, how much would that be moving the wheel out from the stock 4.5" of backspacing? I'm slightly confused by your answer.
Chris
Chris
You're dredging up an old thread. :)
Backspacing is a function of offset. Offset is only more important than backspacing in that knowing it & the rim width, you can calculate an approximate backspace distance.
Backspacing is the distance from the mounting flange to the inside lip edge of the rim. This is important to know because too much backspacing can cause the wheel/tire to rub against the springs, shock, inner wheel wells, etc...
Stock fj80 wheel backspacing is 4.5". Try not to go over that # when figuring out what wheels will fit. Going under that # is perfectly fine, however note that you may be pushing the center ine of the wheel away from where the bearings are expecting the weight of the vehicle.
what if i got the 4.5 on a 9inch wide rim but the offset was -12
Clear as mud?
so 12mm is about 1/2 an inch . with 4.5 BS it really ends up being 4 BS?
so the MT rims with the 4.5 bs and 12mm offset have a 106mm bore . my procomps are 108. will 106 work ?
