What are these?
Merced, CA
I think the first one in the water separator, assuming it's bolted to the air filter instead of under the truck since its a transplanted 3B.
The second one I have no idea....
the second is your vacuum reservoir for the brake booster.
the first does look like a water separator, probably.
x2 The water separator should have a drain for letting water out. On a factory diesel that wiring would light up the dash to tell you the water separator is full.
That model vac reservoir was the unit used in the 60 series and later in the 7* series until 07
The later models had some sensors for low vac and there are versions for L and R side of engine bay ,depending on the engine
The first one could be a water separator but it's on the wrong side for a 3B. The second is the vacuum resevoir for the brake booster. On the BJ60 the water separator is mounted down on the frame rail and, yes, they are stock.
the first is the fuel /water separator
it has a drain on the bottom (10mm) to let the water/dirt out. mine was on the frame rail pass side 3/4's the way back. It was leaking water/dirt/rust/fuel. I opened it up where the switch is on top(water sensor switch) and found some gunk in it and a metal ring bit from the original paper element. I resealed it at the seam and painted it many times. Should work until i buy a aftermarket one. won't hurt anyway. i will locate the new one where you have yours maybe...
I disconnected my Racor on the '55 because it was letting in air and since I've disconnected it there has been no air problems. I'll be installing an OEM separator down low where it's under pressure from the fuel in the tank. Up high like in the picture puts the separator above the fuel level in the tank and could allow air to enter the system (that's what I think was happening on the '55). I'll try to post a picture of the '55 engine bay with the Racor location shown so you know where NOT to install it!
Remember, the separator is under a vacuum when the engine is running as it is sucking fuel from the tank unless your separator is downstream of the fuel feed pump (special hoses would be required for that to connect to the fuel banjo fittings).
What are the symptoms of this happening.
Tim
The truck will initially loose power and seem to hesitiate. Occasionally it will recover if it can rid itself of the air otherwise as the air builds up the truck will stall. A simple couple of pumps on the priming pump at the injection pump will clear out the air and you're good to go until it happens again.
Last weekend this happened about 4-5 times last weekend in Tapachula, Mexico. After I bypassed the Racor it ran fine. I'm going to give it a few more weeks and if I have no air problems the Racor is coming out.
Here's a shot of the engine bay of the '55. The Racor filter is visible up beside the booster and battery.
