What are these hoses?
Hello,
As the title suggests, what are these parts?
*The one attached seems to be leaking what looks like oil. I figure I should probably replace that.
The next hose was just laying underneath the rear baffle of my intake hose. I really have no clue where it goes as I can’t find an unconnected vacuum tube.
*The first picture is up close, next to the oil cap and the second photo is just from further away.
**the piece I’m holding is the loose one
First picture is the PCV valve hose and the part weeping oil is a heat shield of sorts for the PCV valve.
The disconnected hose should be connected to the box that connects to the air intake and is mounted on the engine PS over the spark plugs, which you apparently removed prior to photos.
After putting this box bac in with everything else, I notice a vacuum thing here. Where on my engine does the other end connect tho?
Nevermind! I found the area it connects it between two pistons. I used a towel and just lightly put the tip in because the valve looked dirty. It’s compeltly back on the inside, is that normal?
I’m not currently able to look at my engine at the moment maybe someone else will chime in, sounds like you’re headed in right direction
Hello,
Coincidentally, I just ordered PCV hoses for both my 2004 and 1998 today. Looks like yours is the earlier model. Also picked up the PCV grommet and insulation cap 90480-18001 and 12235-50010. Got them from local dealer (they match online prices)For 1998:
