Wet passenger carpet
pull the rubber plugs under the rocker panel . Snake drains with weed wacker string. I believe the rears come down the b post . I dont recall
The rear drain openings (in the drain pan for the sunroof) are too far back IME to get a string into them from above but IME they tend not to get plugged. You could apply a very short blast of very low air pressure into the open end of the rear drain hose where it comes out of the inner aspect of the rear quarter panel ie: under the rear of vehicle. Do that while someone else is watching from above (sunroof open) to see if anything comes out. The risk is you could pop the drain hose off the nipple on bottom of the drain pan. If that happens then you may have to remove the headliner to get to the drain hose and reattach it, so proceed at your own risk.
