Wet carpet cargo are
A few months back I had a wet DS and PS and through the help here I found out that the drain slits where clogged.
Now it's the rear , I opened the rear panel and found out I had water coming in from the rear window
Also did some research and found this piece of plastic, do I need to seal that hole ? What sealant shld I use?
Also saw this , again does this need to be sealed or replaced?
Whats gonna be the next thing to leak ? I just washed my entire carpet last summer (slap head) . Thanks
The 80 is the only Land cruiser I've ever owned that leaked- and the only land cruiser that doesn't smell like a Land Cruiser-
doc W said:
Had the same issues here is the link for the fix: https://forum.ih8mud.com/80-series-tech/250940-water-leak.html
I sealed up the holes under the sliding windows and carefully cleaned the rear vent assembly per the link above and no leaks!
Good luck with it - you can eliminate the leaks.
Thank you very much , I then started tackling this job and here's some pics
Below is the outer casing vent , just noticed that this is where the water got in due to that seal not doin the job , do I have to take that off and run a sealant around it? Or put it back with a sealant ? Thanks
I also wonder if the precious owner got stung by those lol
So my rear carpet has been getting wet too. My little trim piece outside the left side sliding windows is missing so I know that I have four holes letting water in the quarter panel. Actually eight because of the fender flare holes! That water usually exits out the bottom drains except when they get clogged with mud. But I noticed that my carpet was wet even though I know that the bottom drains are clear. So upon further investigation I would like to blame the bottle jack mount.
There is a trim hole directly over it that drips and fills it up. There is no drain hole in the bottom of the jack mount so when it gets full it pours over the lowest side that just happens to be the part that comes in and overhangs the carpet area. I am going to drill a drain hole in the jack mount and hope this fixes it. I can’t believe I didn’t notice this before. I blame the plastic trim cover for covering up this issue! I live in southern AZ so the moisture thing is never high on my priority list, but we just had three days of rain and I noticed some things rusting on the rear carpet. I only checked on them because there was a new (or maybe just more pronounced) funky smell coming from the back.
I’m experiencing a similar issue. My drain slits in the window appear clean as does the tube that carriers it beneath the interior trim pieces.
Thoughts on the location of water ingress? It’s only just damp in the very rear corner of the PS.
Thanks for any guidance that can be given. I’m tight on time these days and need to keep diagnosing time to a minimum if possible.
Sprinkle talcum powder on the wall of the rear quarter, will help you trace the source
