Went looking gave up
Sandy Utah area
Thinking of going to 35 since Im pretty much ready to go for it and I need new tires anyway...but...Im not getting a tire swing, and Im not putting it inside, whats the info on fit under the truck in the stock location with a 35 vs 33. The whole idea of going to 35 would be increased departure and more better wheelin generally...but...if the spare sticks down more that I gain in height, whats the point? I have the landtank spare tire relocation kit, anyone know how a 35 fits underthere?
I have the tire lift kit and the factory hitch removed. It barely clears and I have to really line it up perfectly to make it work. It comes off when I go offroad. It would get hung up on everything otherwise. I'm running ko2s, fwiw. I think they're a little smaller than some, so ymmv
thanks. Yeah, I could take it off wheelin but...Im not wheelin that hard. hmm.
315 ko2s on Ome 850/860
full
It’s a Wits’ End product developed by Adam Rutherford ;)
Your max diameter is 34.25”. Your panhard and/or hitch are the limiting factors. I do have customers who can fit up to a 34.5” by keeping the tire deflated.
The mod doesn’t lift the entire tire so much as it levels it out. Look at the bottom of the tire. See the highest point of the tire? With the lift mod the entire tire will be at that level instead of looking like a saggy diaper :P
If your own statement is accurate i would mount it underneath there and be done with it, if you ever really wheel your truck in the rocks where you might hit it you'll be fine. My friends call mine the rubber skidplate!
Well I do some but I'm not rock bashing. Lockhart basin/Rose garden Hill is about my limit.
Will you be running 16s or 17s once you go to 35s?
Yeah that what i was thinking, find a pizza cutter just for a spare that would work in a jam. A 255/85/16 Maxxis Buckhorn is around 33.3 inflated...I'd say close enough to most 35s that really measure 34.5". Expecially if you think about playing with air pressures...
FWIW, I use tirerack.com's spec chart & it usually is about dead right.
I'd find your favorite flavor of tire, and if they carry it, check the specs vs framewidth.
Seems most 315/75r16's are 34.5" & the same in a 17" is a real 35".
At least based on Dad's set of BFG rubber on H2 wheels on his latest project car / COE truck he's building.
