Welding on Sliders
Grench,
so your EFI ended up being your problem? I was curious after following the thread. I've welded on to the frame of all my Toyotas and never had a problem.:confused: Of course, most of them have had those strange carb do-hickeys...;)
Yes. I suppose I should add another post onto that thread to 'close it out' now. At the time, I was waiting for the EFI to wind up not being it and on to the next step. There were so many.
The only thing that I can point to that would have fried my EFI computer during the time when I installed the 2nd gas tank was welding the bracket / hitch to the frame. I'll weld on it again someday, but the EFI computer is going to be sitting on the passenger seat when I do.
all the cool cats have their sliders welded to the frame.
Ditto what Adam said on the Toyota frames. Are there any manufacturers that still use hardened frames?
I can't recall if the battery was connected or not when I had mine installed but it is a very good idea to disconnect both leads.
If you have plans of selling your rig and want to transfer sliders or ?? to a different truck then bolt them on otherwise components welded to the frame by a competent person are the way to go. Have you ever heard of anyone with welded sliders saying the mounts loosened or they got caught on a rock?
...otherwise components welded to the frame by a competent person...quote]
These terms are being thrown around so loosely. I prefer to be referred to as a poorly trained, unhousebroken monkey (thank you very much);p
Competent is somewhat subjective. You may be competent to weld sliders to a frame or building a roof rack or fabbing a bumper but you may choose to pass on welding steering/suspension components. It is all in your experience and comfort level.
Oh yeah, for the right amount $$$ and time we can train you to be housebroken. :D
You would want to stitch weld it... too much heat would weaken the frame, but you have to remember that you are 1) adding matterial to the frame and 2) it's a boxed frame, so I wouldn't worry about it too much. :flipoff2:
Yeah, that navy tech recommended just that, too.
When I welded the spring mounts to my '85 4Runner frame, I did the same thing: 1 inch "stitch" welds. Keep the frame heat low.
That vehicle was my DD for 18 months. Drove it overloaded from ID to NV (~650 miles), and from LV to LA and back. Offroaded it w/o too much kindness. No sign of cracks in the welds.
A trained/experienced welder told me the welds looked good: good puddle, consistent, no pits.
So, for me, the two pieces of advice look good: stitch weld, and don't worry about welding to Toy frames. Just don't get them too hot, which can lead to warping and holes appearing in the frame.
-Dan
welded and they hold up well when the weight gets applied by a rogue rock...
Do you know the one about how if you build one bridge, no one calls you a bridge builder, but you go and...
...Anyways, I've never been called a welder or an engineer, so as a result, my philosophy has always been to overbuild as compensation. To date, either my philospohy works or I'm extremely lucky.;)
Back to the subject matter of this thread, I welded my sliders to my (now dead) Cruiser. On my '87 minitruck I welded all of my spring and shock mounts to not only the frame, but the axle housing as well. I've had many things break on my vehicles, but it is always a weaker part than what was fabrimocated, with the exception of my custom fat-hula(guy)-dancer-with-uke mount.
IBCRUSN, ya really think that some $$$ and time can rehabilitate a lifelong fecal-flinger???:flipoff2:
All it takes is one followed by a lot of zeros. I can PM you were to FedEx the cashiers check and we'll get started. :D
I dont like the methods of most of the bolt on sliders I have seen.
I will make my own bolt ons.
I like to keep things removable.
Lets say some drunk smacks one end of the vehicle and insurance pronounces it RIP I want to be able go get another used 80 and swap it all over and get back to the way it was faster.
Sleeve the frame at your mounting locations. The sliders can be installed without hanging below the frame and still be removable.
It was my original plan then I decided it was too much work. I went with .25" plates ~6" x (the height of the frame) + .25" and added a ~6"x(frame rail width) on the bottom. There are many inches of bead keeping it all together.
If you end up sleeving the frame make sure to post it up. It's a dam good idea and a very clean mounting system.
