nab856
We are working on aluminum intercooler duct work for confined spaces.
TIG....
TIG....
Mounting worked out!Patience! We still need to decide where and how to mount the intercooler. Then, build the mounts.
Here is the project context
A great suggestion! Buying the tubing bends commercially would eliminate much of the build time. We are working on air tubing for two intercoolers. One intercooler will be used for the turbo-supercharged engine. The other for just a turbo engine. The two turbo/exhaust side tubes and the intercooler-to-supercharger tube can be done with the tight radius bends from VIBRANT tubing. However, the intercooler to throttle body tube for the turbo engine has very little space. In this area there is a throttle position sensor and a coolant pipe that the aluminum tubing must work around. Fortunately, both the intercooler and upper intake plenum locations can be moved. After repositioning the intake and intercooler, all four tubes could be made with commercial bends.I used VIBRANT tubing for my FMIC on my 12HT few years back. They make a nice tight radius tubing,
not sure as tight as this effort, but maybe worth a look?
Thank you for providing the actual bend radius. Excellent information! The yellow painter's tape suggestion is handy. Any tips that make a project easier are always appreciated.I used aluminum. 12HT on a 60 had to bring the inlet low and then straight up past the air cleaner. As you
can see the extension I needed to clear the motor. That's the inlet flange there. The tight 180 is pretty tight.
Suggest SS to be honest. Make sure you clean out the inside once you are done. Yellow painters tape holds tight and
just burns off as welding. Kinda handy. Hope this helps you a bit.
View attachment 4192279View attachment 4192280
Reconfiguring hoses so the intercooler will fit on top of the valve cover.
Found a bending procedure in this video on Youtube:
He is a Toyota guy!
Here is what we used. Some modification to make a bend further from the end.
It's a spring tube bender set. Available from a variety of tool purveyors.
$50. Really? It takes longer to boil the water than bending the rubber
