Welding axle instead if c clip
If your thinking about welding the inner ends of the axles to keep them in position, instead of using the proper C clips, FORGET IT! You will NEVER be able to pull those axles out for service/ repairs in the future. What happens if you have an axle seal go bad? Sounds like you have some other kind of problem?
Probably the rear semi float 80 axle. Are you wanting to weld the diff so it's locked like a spool?
Gotta be the front axle "Martack", to keep the axles from moving into the differential too far, while leaving off the C clip that normally keeps the inner shaft in the birfield.
sorry ..yes this is the one i am talking about ..i live in florida and we do alot of rides that include water just thinkin it would be easier when i pull axle to do maintenance and check the grease instead of messing with the c- clip in the birfield all the time
