I took the whole 3rd out of the housing, not to hard to do. But left the gears in, and clean it really good. and Use a lot of fouilo ? (SP) paper around the gear and stuff I didn't slag on
how about method #3?!
i learned this from FC. he welds a couple of teeth ( basically fill in the low areas between the teeth on three teeth adjacent to each other) on opposite sides of the spiders and 4 spots on the side gears. then they are installed as if they were regular gears. the welds act as stops and do not allow the gears to turn any further. i guess a pic would help. this allows a little rotational difference yet keeps the parts "serviceable". welding the side gears in 4 spots also allows you to rotate the gears by 90degs should a problem arise.
we've run lincoln-lockers that way for years and it works extremely well.
That would be simpler yet considering how easy it is to pull those parts and weld em up on the bench.![]()
